Disapointing Dyno Numbers
Old Nov 23, 2005 | 04:57 PM
  #16
crAzy95z28's Avatar
Re: Disapointing Dyno Numbers
have u done the TB bypass?
thats a 6rwhp gain
Old Nov 23, 2005 | 05:21 PM
  #17
3gc's Avatar
3gc
When I got dyno'd in june having just a cat back, cut out, intake and free/cheap mods i put down 258 hp. I added those parts that I listed earlier. I was expecting atleast 300hp, but i guess 11 shy of my goal isn't too bad.
The motor has a little less then 87k on it.
I have a stock MAF not a ported one. I just used Pamena for the dyno, PCMforless did the tune. AFR stayed at around 13.5 or so throughout all the pulls.
Roller rockers and valve springs along with a yank torque converter and Mickey Thompson ET streets are this winters projects. Mild cam will be thrown in, in the spring. Hoping for a mid-low 12 after that.
Thanks for all the replies.
Old Nov 23, 2005 | 05:23 PM
  #18
3gc's Avatar
3gc
Also, the first run was with the cut out closed, 2 others were with it open. Proof of a solid 10RWHP gain with the cut out.
Old Nov 23, 2005 | 05:34 PM
  #19
faded93bird's Avatar
Those are very good #'s through an auto. I would not be dissappointed at all.
Faded
Old Nov 23, 2005 | 08:02 PM
  #20
1SlowFormula's Avatar
Originally Posted by BUBBA
Actually, I believe the Mustangs read around 10-12% lower. Could be wrong about that.
Bubba,
here is mine on a mustang dyno with the full stock exhaust mods in my sig...
here is one with the cutout open...
We were not sure where to set the end of the run on the dyno computer so the full exhaust run was set to kill the run at 140 MPH, and then after seeing the results it bumped up to shut down at 145 MPH, and since I have 2.73 gears I should have told them to shut it down at 160, but I didn't know that at the time... I was just under 300 and I didn't even get a full run, this is why I thought Mustang's read higher...
Old Nov 23, 2005 | 11:37 PM
  #21
89385formula's Avatar
I think those are some very respectable times through an auto and as few mods as you have....definately don't be disappointed.
Old Nov 24, 2005 | 12:32 AM
  #22
JKDZ28's Avatar
Man, I think your numbers are exactly where they should be.
Dont worry about it, your fine
Old Nov 24, 2005 | 02:34 AM
  #23
amean94ta's Avatar
a mustang dyno would read lower it has eddy current or to explain force against the wheels to sim the earth where as a dynojet is just free wheeling
Old Nov 24, 2005 | 12:31 PM
  #24
Harvey's Avatar
Question Re: Disapointing Dyno Numbers
I got 280 RWHP and 310 RWTQ with my mods below MINUS the E-WP.
Wayne
Old Nov 24, 2005 | 02:41 PM
  #25
Wayne
You are a M6 thats why. Auto's dyno quite a bit lower due to the greater parasitic loss because of the automatic tranny.
Old Nov 24, 2005 | 04:36 PM
  #26
SStrokerAce's Avatar
Originally Posted by madwolf
The reason you're disapointed is because you've set your expectations too high. It happens very often.
289 RWHP for a bolt on automatic is very good. You are getting knock retard though.
Yep, you are always happy if you expect nothing and get more than you wanted, it's all mental. Overall it's not bad.
Bret
Old Nov 24, 2005 | 11:21 PM
  #27
amean94ta's Avatar
also you guys are running high 12's low 13's so really what did you expect?
Old Nov 25, 2005 | 12:21 PM
  #28
Grn4fbody's Avatar
Tune the car, it works wonders
HarleyZ28
Oct 5, 2015 06:23 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
BLK1997Z28
May 7, 2015 03:01 PM
racecarz28
Mar 30, 2015 09:55 PM
Joe Brodman
Jul 24, 2002 05:24 AM
