differences between intake elbows?
Old Mar 28, 2007 | 01:47 PM
  #46
LiENUS's Avatar
Originally Posted by BTC
Well, I've decided to get a 1LE. That's one more decision out of the way.
Since electrical tape was used anything you put on is going to feel sticky. Get some form of solvent and clean off the residue from the electrical tape before you put whatever replacement elbow on. Throttle body cleaner should work fine. If not autozone carries a "Gasket remover" spray that should do it just be sure to follow up with TB cleaner because the gasket remover spray WILL eat your new rubber elbow.
Old Mar 28, 2007 | 03:31 PM
  #47
Originally Posted by LiENUS
Look again the 1LE has the same part number stamped on it as the stocker unless they changed it for the 95+ f-bodys.
I don't care what it has stamped on it. Mine is obviously thicker.
Old Mar 28, 2007 | 03:32 PM
  #48
My intake often feels as if it's actually stuck to the throttle body. But, that could be due to the electrical tape someone used attempting to "repair" the tear.
A thin film of Vaseline will make it go on easily with no catching or tearing.
Old Mar 28, 2007 | 06:29 PM
  #49
LiENUS's Avatar
My stocker and my 1LE are both the same thickness and same part essentially. The part numbers for 1LE and stock are both stamped on it.
Just measured the 1LE and stocker. 1LE thickness at the TB 0.26" stocker thickness at TB .27". stock is .01" thicker than the 1LE measured with dial calipers properly zero'd. This includes the lip I do not have the tools in my toolbox to measure past the lip however my neighbor should and I will try to borrow his calipers tomorrow.
DirtyDaveW
Mar 15, 2015 07:01 PM
RedLineRev
Jan 23, 2003 03:51 PM
slothgrant
Aug 22, 2002 03:01 PM
30thZ286speed
Aug 3, 2002 04:54 AM
