Did I botch my fuel pump installation?
Old Jan 30, 2005 | 01:53 AM
Mullet Z28's Avatar
I'm running a Racetronix intank pump and suspect I may have botched the installation. I have an intermittant hard starting problem. Somtimes it fires right up, but sometimes I have to crank it for a long time and give it gas to get it to start.
When I was installing the pump, I tried tightening the clamp on the corrugated plasic tube coming out the top of the pump as tight as I could, but maybe it wasn't tight enough. Could that be causing my problem?
Old Jan 30, 2005 | 02:08 AM
CamaroSS30thAnn's Avatar
Re: Did I botch my fuel pump installation?
same problem happened to me , as my car wouldnt start, u may need a new pump ,
when i did my pump the first time i didnt tighten that line up enough it came off a week later , i did it again and i made it as tight as i could , car wouldnt start
turned out i needed a new pump , tightening it to much may have kept the check valve form opening and closing,
send it back , it should be waranteed
Old Jan 30, 2005 | 02:32 AM
1racerdude's Avatar
Have you checked your pressure regulator? It may be bleeding down.
Old Jan 30, 2005 | 05:37 AM
Racetronix's Avatar
Get a fuel pressure gauge and take some measurements.
Old Jan 30, 2005 | 02:17 PM
Mullet Z28's Avatar
I'm getting about 40 psi at idle. I haven't checked to see how quickly fuel pressure bleeds down after I shut off the motor and won't be able to until next week (car is stored far away from me). Would the type of intall error I think I made cause the problem I'm describing?
Old Jan 30, 2005 | 02:31 PM
Racetronix's Avatar
Yes, if the flex tube was not installed onto the black push-lock connector properly or you damaged the pump's outlet.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
