delteq questions
Old May 1, 2004 | 02:20 AM
96birdlt1's Avatar
Question delteq questions
I have searched for delteq on the forum, and everyone has said that it is better than the stock optispark, but is it good for use with nitrous or a blower?
I haven't seen anyone talk about the advantages or disadvantages of the delteq in high performance situations.
It seems like a great system, but I don't want to have to scrap it as I start to build more power.
Any help would be great.
Joe
Old May 1, 2004 | 04:10 AM
Alex94TAGT's Avatar
I cant speak on Delteq's behalf, but from what I understand, the Opti-direct kit does not have a built-in rev limiter nor an ignition-retard feature like that of the LTCC.
However, you can use a DIS ignition box with the kit. Looking in Summit's magazine, it appears that the part number for the 4-channel MSD DIS ignition box is MSD-6215 -- roughly $330. From the looks of it, you might also have to purchase the Tach Adapter p/n MSD-8912 at $50 (not entirely certain). So, it's not cheap, but it can be done. http://www.msdignition.com/sci_4.htm
Other than that, I would assume the Delteq is a great upgrade for both high- and low- horsepower applications. You can saw-off the rotor within the opti so it wont fly apart at high-rpm, you'll have four massive ignition coils instead of one (plenty of dwell time), not to mention it's a complete easy-to-install kit. However, it will still utilize the optical portion of the opti -- at least for the time being.
I figure that I've seen some guys online that have replaced two or more optisparks in a single year. For the same price (at least for the $300 unvented 1993-1994 models), you could get a coil-conversion, and not have to worry about the majority of the problems associated with the opti. Pay $400 for an ignition box, and you'll be set for anything you can throw at the motor.
I've already placed my order, so my views may be slightly biased.
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Ari G
Dec 11, 2014 03:21 PM
