Dart LT1 heads
Old Oct 10, 2007 | 09:52 PM
  #16
9formula4's Avatar
let me know on those bare castings bret. I am thinking these would be a great head for me.
Old Oct 11, 2007 | 07:14 AM
  #17
Vicious95Z28's Avatar
Originally Posted by 96capricemgr
I was going to say rumor has it someone already sent a set to them to play with.
Yeah, I can verify that, it isn't rumor.
Old Oct 11, 2007 | 08:44 AM
  #18
speed_demon24's Avatar
I'm guessing they are yours? Have you heard any word on how good they are in stock and ported form yet?
Old Oct 11, 2007 | 10:41 AM
  #19
SStrokerAce's Avatar
Originally Posted by mdacton
So have you seen these on a bench yet? I remember we talked about them a long time ago......... I want to know if they are worth it. I have quite a bit in a set of heads I haven't even used yet
Well any Dart 180, 200, 215, 230 new Pro1 head is worth it... any of them can be ported OUT to the same amount. I've seen them move 320+cfm in the size range right for a 383, so yeah they will work.
I'm actually waiting on a set from Dart right now... I get them a certain way from them for what we do with them so it's not like getting them from Jegs. When I talked to them last week they had castings with VJ's in them ready to rock.
Bret
Old Oct 11, 2007 | 02:18 PM
  #20
T/A lt1's Avatar
Good deal, looks like someone is helping us LT1 guys out.
Old Oct 11, 2007 | 08:05 PM
  #21
pyro719's Avatar
Strokerace do you have flow #'s for the 180's out of the box?
Old Oct 11, 2007 | 08:08 PM
  #22
mdacton's Avatar
My guess is no.......I would not trust any numbers unless they came from the man that flowed them. But the numbers are not going to mean much out of the box.......its more of whats there to work with and how much can you get out of them.
Old Oct 11, 2007 | 08:33 PM
  #23
9formula4's Avatar
I want to know the flow out of the box. I am leaning towards these over a stock casting ported. I think with a little help from LE i could have a great set of heads.
Old Oct 12, 2007 | 07:32 AM
  #24
No they aren't mine, wish they were, I talked to the man that sent them though.
Old Oct 12, 2007 | 08:59 PM
  #25
matLT1's Avatar
Will only 180's be available for the LT1 or will Dart offer 200, 210, 230 ect?
Old Oct 13, 2007 | 09:02 AM
  #26
quickSS's Avatar
I'm giving these heads a try, (the bone-stock-out-of-the-box-version). Seems to me that they would be a good low $ head for a 383LT1. They come with the Comp 987 valve spring and that won't handle an aggressive cam. But I think that spring will handle a GM 846, (so that's what I put in the motor).
Possibly late this month or early next month I'll have the 383LT1 with the out-of-the-box Dart heads/846 cam running in a heavy Impala SS. I expect good performance but not amazing performance. If the heads had a NeWen valve job, porting and super nice valve springs then and only then would I expect amazing performance.
The build web site for that motor is at http://www.karl-ellwein.org/ERE6/ERE6.htm I started the motor 1 year ago and we were just waiting on the customer to decide on cylinder heads.
I do have one actual test of the Dart LT1 heads. The Darts replaced a set of mildly ported GM iron LT1 heads on a stock bottom 350LT1 with GM846 cam The car ran the same ET/MPH. No improvement. But the answer I got from that was that the Darts at least perform as well as mildly ported GM LT1 iron heads.
I do have 2 bare sets of Dart LT1's going to Phil at Ai. We are not making a big project out of it and they won't be given top priority for CNC machine time. But it will be neat to get Phil's opinion. My hunch is that the TFS heads are generally nicer for the LT1 fully ported and that the Darts will be better for the budget (out-of-the-box).
Karl
Old Oct 13, 2007 | 10:02 AM
  #27
rickreeves1's Avatar
Karl
So you think the TFS heads will have more for the porters to work with? Keep us informed when you get some results. Thanks
Old Oct 13, 2007 | 11:02 AM
  #28
seawolf06's Avatar
These have the option to have smaller chambers right out of the box without extensive milling correct? I know TFS wants a lot for milling and the chambers are huge to start with. Also, do these need offset rockers or will they work with stock-style valvetrain?
Old Oct 13, 2007 | 11:17 AM
  #29
quickSS's Avatar
When I talked to Dart about 6 months ago, (right after they made 20 sets of LT1 heads), they said the heads were all 60cc chambers and the assembled ones would all have the Comp 987 spring installed at 1.80". They come with guide plates and 3/8" rocker studs, (in a bag).
It looks like Jeg's has a relationship with Dart to get other chamber sizes. That may be just their special deal. Jeg's also shows a choice of valve spring. I'm sure all of the choices are case by case and the cost will be added for the better parts and time will be needed for assembly.
My 1st 2 pair of Darts were via my normal wholesale engine builder parts supplier and that is when Dart had 20 sets on the shelf. Right now Dart is out of stock, (apparently).
Ai has turned me onto another Dart dealer that has some LT1 heads, (bare), in stock right now. Possibly more info will be available soon after I see what they have.
They do have huge pushrod holes so I'm sure any rocker will work. I'm using Probe shaft rockers (standard SBC) and they fit like a glove.
Karl
Old Oct 13, 2007 | 11:27 AM
  #30
seawolf06's Avatar
That's interesting. If they sold them that fast, maybe they will make a larger batch next run. I can't wait until I can just get a bare set and get them ported. Do you know when AI's sets will be available? They'll work with the PAC beehives, just need 8mm valves, retainers and locks, correct?
