Darn Fuel Problem
Darn Fuel Problem
Got a pressure gauge put on the fuel rail... was at 60psi!!
Well, dropped it down to 41 with vacuum line on, 45 with line off BUT!!
If you goose the throttle... the freakin pressure drops? If you turn the car off... pressure drops?
I can't figure out why the pressure goes from 42-43 (idle) to 35-37 (little rev)? That's with no load on motor
Re: Damn Fuel Problem
When was it at 60psi? Was that right at startup or something? The other #s sound fine to me, but Im no pro.
BTW, Im copying your engine, pretty much. VRE is building the 4 bolt forged shortblock now, and Lloyd will have a set of heads to port soon
Im trying to go as agressive with everything as possible though, as its not a daily driver, so we'll see how our #s compare. I will then spray a 200 shot
Originally Posted by TQdrivenws6
The pressure drop at rev sounds like a bad pump. Dirt in the check valve can happen if you don't wash out the tank when you put the new pump in.
Originally Posted by ChrisUlrich
I love the car when it runs good... it's an absolute powerhouse at every rpm.
What numbers sound good? The decrease in fuel pressure?
Re: Darn Fuel Problem
Originally Posted by turbo_Z
Are you 100% sure you are using the fuel gauge right?
When you turn your car to the 'on' position and the fuel pump charges the fails and lines with fuel you SHOULD get like 42ish psi, WHEN you turn your key off, the pressure SHOULD hold at that, and if it drops it should be over time, like an hour or so, maybe more. When i had a faulty check valve in my stock pump i would charge the fuel rails by putting it to "on" and in like 30seconds it would drop to 0. I have the same walboro pump as you chris (though i got the racetronix kit, same pump though). You need to grind out the inner portion of the tank sump (has some fins in there), did that guy do that? How fast is your pressure droping from full to 0? 60ish psi is kinda high at idle no?
