Need Timing Cover
Old Mar 9, 2006 | 02:31 PM
playa7970's Avatar
Need Timing Cover
Im about to purchase the cloyes double roller does anyone know where i can buy a timing cover for my 94 lt1
Old Mar 9, 2006 | 03:10 PM
Javier97Z28's Avatar
Moderator
Re: Need Timing Cover
Like.. a stock timing cover?
There's no aftermarket timing covers that I know of for our cars. You just have to clearance your stocker.
Put some grease on the chain and bolt the timing cover onto the block. Rotate the engine by hand and see where the grease is rubbed on the cover. Grind it down and test fit it a couple times.
As I like to say..
Better safe than metal shavings!
Old Mar 9, 2006 | 03:25 PM
playa7970's Avatar
well golen is building my 383 short black and they need a timing cover from me and i dont want to take mine off u know
Old Mar 9, 2006 | 03:30 PM
Silvershark's Avatar
I have a stock 94 timing cover that has been painted black with high heat temp paint. It looks excellent. It is the 94 non vented version, not the 95 vented version. It has all seals and everything. If you need it just hit me up. You pay shipping and $5 and its yours.
Old Mar 9, 2006 | 03:32 PM
Moderator
Oh, ok.. in that case..
Basically you could pick up a used one or purchase a new one from someone like Jason Cromer. I can get you some part #'s depending on what you need when I get home.
Old Mar 9, 2006 | 05:38 PM
Demon's Camaro's Avatar
On the 94 you will NOT be able to use the cloyes double roller, you will need a 95 timing cover, along with a opti conversion.
Old Mar 9, 2006 | 07:07 PM
playa7970's Avatar
well in that case does anyone have a 95 and up timing cover they wanna get rid of
Old Mar 9, 2006 | 07:43 PM
The best place to post to get it is in the "want to buy" section. It shouldnt run you more than 40.00 for the cover. You will also need a vented opti, a newer opti pig tail, gasket set, and a newer cam for a 95 and up with the longer dowel pin.
Sorry to rain on your parade!
On a happier note it is well worth the extra cost for this though.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
*Emilia*
May 13, 2015 09:05 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
