damper problem
Old Apr 23, 2010 | 08:10 PM
Gio93z's Avatar
damper problem
Just purchased ATI Super Damper 917268 for my 93 LT1 Camaro. The stock hub on my car does NOT have a key-way slot on it. It was just press fit and held with the damper bolt. The ATI damper has a key way in it to accept a key way. Do I need to get a key way and use it or just press it onto my crank snout just like my factory one??
Also, the damper tapered washer which will sit under the damper bolt head is pretty thick....[B]should I only use the supplied ATI washer or use both the ATI washer and the stock thick washer?. [/B]
Thanks!
Old Apr 23, 2010 | 08:37 PM
The 360* of timing marks on the ATI damper will be rendered useless if you don't use a key. What's the big deal about spending a buck or two on a key?
Old Apr 24, 2010 | 04:52 AM
Gio93z's Avatar
no problem getting a key - just wanted to ask
Old Apr 24, 2010 | 07:40 AM
rskrause's Avatar
Moderator
Why GM didn't put a key in the damn thing in the first place escapes me. Always use a key, or two.
Rich
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
