Daily Driven 383
Old Jun 29, 2005 | 03:12 PM
  #31
megladon's Avatar
Re: Daily Driven 383
Originally Posted by megladon
YUP, only i'm going full EXTREME on mine with the T56-M6
Only thing stock is body, and some interior
this is how it sit's now
Old Jun 29, 2005 | 04:37 PM
  #32
97WS6SCharged's Avatar
That looks pretty good. It'll look better when it's all one color.
Old Jun 29, 2005 | 07:26 PM
  #33
SStrokerAce's Avatar
Originally Posted by 97WS6SCharged
I think he's referring to actually balancing the crank with mallory metal. Even with a little extra metal to balance an Eagle crank, I doubt it will make up the $400 dollar difference between the two cranks.
Yeah and you only need the Mallory if you don't have enough mass in the counterweights... As I said.. the 383 Eagle 4340 3.750" stroke crank that was just balanced internally with a JE blower piston, Eagle 5.7" Rod, 45g's of rings and a 140g pin (which is a HEAVY setup) didn't need it and this is with a 5.7 rod which reduces the counterweight clearance on the bottom of the piston. NVetro's thread has a Dragonslayer with basically the same deal needing $700 worth of blance work vs. this Eagle with a $250 balance job and it's perfect. Then again, he had a lot of "problems" in his setup.
Bret
Old Jun 29, 2005 | 10:37 PM
  #34
Ouch.
whitehooptie
Jul 12, 2015 06:10 PM
asilomar244
Jul 12, 2015 05:53 AM
Boss002
Jul 9, 2015 03:33 PM
Jim S. '95 Z28
Jan 22, 2002 05:44 PM
