Crankshaft pulley question
Old Jun 28, 2008 | 04:29 PM
Red5.7's Avatar
I am working on doing an opti swap and removed the pulley from the hub that is bolted to the crankshaft. The hub is still bolted to the crankshaft.
I have an underdrive pulley that is pressed in to the original factory pulley.
Each pulley has 2 arrows and they are pointing at each other. I did not mark the location when I removed the pulley. Is this going to cause a problem?
On the actual hub there is a lip/ear/bump between one of the points on the hub that the pulley bolts too. Are the arrows on the pulley supposed to align with the bump on the crankshaft hub or does it not matter how it goes back on?
Old Jun 28, 2008 | 06:04 PM
Stl94LT1's Avatar
Won't be a problem, the pulley/dampner will only go back on one way.
Old Jun 29, 2008 | 11:18 AM
.... because the three "arms" on the hub are not equally spaced.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
1LEThumper
Jul 14, 2003 12:45 PM
