crankshaft position sensor question
Old Sep 14, 2011 | 12:23 PM
udlose94z28's Avatar
ok guys some lt1's carry a crankshaft position sensor.. will a lt1 without the sensor sit in an work in a car formatted for an crankshaft sensor... if so what has to happen? i heard the cps just reads misfires and can be tuned out.... any advice is appreciated thank you
Old Sep 14, 2011 | 05:05 PM
Re: crankshaft position sensor question
Originally Posted by udlose94z28
..........will a lt1 without the sensor sit in an work in a car formatted for an crankshaft sensor... if so what has to happen?
The OBD-I LT1's (93-95) do not have a CKP sensor. If you install a 96/97 OBD-II engine, with a crank position sensor, and continue to run the OBD-I PCM, there is no place to connect the CKP sensor, and nothing will happen. Engine runs fine without it.
If you have an OBD-II LT1 (96/97) and install a 93-95 OBD-I engine without the CKP sensor, there will be nothing to hook up to the CKP pin on the OBD-II PCM, and you will get codes for the missing CKP sensor. That will not affect how the engine runs. The CKP codes can be "programmed out" of the OBD-II PCM.
As you noted, it's only purpose is to detect misfires.
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Injuneer
Dec 15, 2014 09:36 AM
