Crank wont turn
Old Apr 17, 2007 | 04:30 PM
  #16
InsuranceGuy's Avatar
Check this out for what a flywheel turner tool
looks like.
http://toolmonger.com/category/manufacturers/lisle/
Old Apr 17, 2007 | 04:35 PM
  #17
NovaTodd's Avatar
I can't fnd the item number on Harbor Freight's website. But try this: http://store.summitracing.com/partde...5&autoview=sku
Item # WMR-W80510
In a pinch, a big screwdriver can also be used to turn the flexplate as ta4me says.
Old Apr 17, 2007 | 05:49 PM
  #18
Boosted_Z28's Avatar
Originally Posted by SJG3RD
Use a mid sized breaker bar and stick it into the flywheel and turn it with that? I might give that a try as well.
thanks
The pry bar or long H.D. screwdriver goes in between the teeth and then you use the transmission bellhousing as the lever fulcrum. This is a very slow process to rotate an engine 360*, but you have a huge amount of leverage.
Is there a gap between the flexplate and the torque converter when you are installing the t.c. bolt(s)? Is the trans fully bolted to the engine, with all the bolts tightened and nothing caught between the engine and trans mounting surfaces?
Old Apr 17, 2007 | 06:14 PM
  #19
SJG3RD's Avatar
Mission accomplished!!!!
Thanks for all the help guys and ideas. I really appreciate it
I used the 5/8" socket and 1/2" breaker bar. I tired it yesterday with a 3/8" flex head rachet and 5/8" socket and it didn't work so good.
I didn't want to Tarzan it like I have done in the past and break something! Is the main reason I wanted to make sure something wasn't going to break.
Thanks again to everyone who responded.
Klypto
Mar 9, 2015 04:25 PM
Chevyguy358
Jan 28, 2015 08:04 PM
Alex Barnes
Jan 24, 2015 10:21 PM
formula79
26
Aug 5, 2002 12:21 PM
