Crank pulley question
Old Jun 29, 2003 | 07:59 PM
Mr.Whitey's Avatar
I just took the crank pulley off to powder coat it and noticed that it has a rubber ring around it. What is that and what does it do? Can it be replaced? I don't want to cure it at 400deg for 30 minutes and destroy it. PLEASE help since I wanted to do this in the next day or two.
Old Jun 29, 2003 | 09:15 PM
The crank pulley is also the "harmonic damper". The ring connects the inner and out portions of the damper, and allows the outer portion to move relative to the inner (hub) portion, to counter the harmonics in the crankshaft. It reduces the cyclic radial deflection of the crank in response to the power pulses.
400degF isn't going to be good for the rubber ring. Why not just paint the pulley? I really doubt anyone will know the difference.
Old Jun 29, 2003 | 11:04 PM
Mr.Whitey's Avatar
Thanks Fred. I was hoping that you would see this tonight and give me an answer. I will just paint it.
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
