Crank Hub Removal Tool
Old Jun 9, 2020 | 05:50 PM
Robb676's Avatar
Crank Hub Removal Tool, What tool do you use after the balancer comes off?
Old Jun 9, 2020 | 09:04 PM
Re: Crank Hub Removal Tool
Shoebox covers the removal of the crank hub in his cam removal writeup. You have to scroll down at least 3/4 of the way to the bottom, just below the red link for “Optispark mounting diagram”. It includes details if the specifics required to avoid problem specific to the LT1.
4th Gen LT1 F-body Cam Removal
Old Jun 10, 2020 | 05:09 PM
Chimera96's Avatar
A 3 spoke wheel puller tool will get it off.....its getting it back on that takes either a home brew one or the exploding wallet Kent Moore removal/install tool # J 39046. Sometimes you can find them on ebay but not heap. I bought one about 20 years ago but it was only $40 then
Home brew would be using the correct size all thread rod, thrust bearing and a stack of flat washers and nut. I made one for a Ford motor I have.
do not use the center crank hub bolt to "pull" it on...you will strip out the crank. Don't beat it on with a hammer either
ShownomercyZ28
Jun 13, 2008 06:30 PM
1quickTA
Mar 1, 2006 09:57 PM
jj93z28
Jul 1, 2004 07:17 PM
jtk
Mar 13, 2004 04:18 AM
jpolz
Mar 25, 2003 11:59 AM
