Crank hub
Old Jun 13, 2008 | 04:30 PM
ShownomercyZ28's Avatar
Crank hub
How do I remove the crank hub? I tried an impact gun with the puller and no luck. I really want to put it all back together, any ideas?
Old Jun 13, 2008 | 04:35 PM
Kevin Blown 95 TA's Avatar
Make sure you are not pushing against the back of the inside of the hub itself to get it off. You might put a screw in the threaded crank hole and push against that.
Old Jun 13, 2008 | 04:37 PM
Well I put the crank hub bolt in a bit and used that but all that did was tighten it back up in the crank.
Old Jun 13, 2008 | 04:39 PM
krillformula's Avatar
I used a tool similar to this:
http://cgi.ebay.com/ebaymotors/Unive...ayphotohosting
when I removed mine yesterday. I think a steeringwheel puller will work.
Just some ideas.
Old Jun 13, 2008 | 04:41 PM
So you put a screw in the crank to push against but small enough so the crank hub can slide past?
Old Jun 13, 2008 | 06:30 PM
Something like that. A hardened rod is the best thing to use.
AviatorDave
Dec 19, 2016 06:35 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Boss002
Jul 24, 2015 10:47 AM
Catmaigne
Jul 14, 2015 05:17 PM
