crank hub question.
Old Oct 29, 2006 | 10:30 PM
sam pace's Avatar
crank hub question.
Will a crank hub off a 95 impala/fleetwood work on my car?
Its a 97 Firebird, and I am doing a double roller conversion.
Any advice is welcome.
Old Oct 29, 2006 | 10:42 PM
Pretty sure the spacing (length) is different.
Old May 12, 2021 | 12:57 AM
Jason Paluszak's Avatar
Re: crank hub question.
Just saw your post online from nearly 15 years ago (haha) about the difference between crank hubs. Did you ever by chance determine if there is indeed a difference between the Fleetwood LT1 crank hub length and the Camaro / Firebird LT1 link? I think I am having that issue right now as mine seems to stick out an extra quarter inch. Thank you VERY much. Jason
Old May 12, 2021 | 01:07 AM
The 1/4” difference is often the result of the longer hub from a 93/94 F-Body (OBD-1, no crank sensor reluctor) and the 95-97 shorter hub (OBD-2, CKP reluctor sandwiched between the hub and the crank timing gear).
Have no idea if that is similar in the Fleetwood. But for example, the Corvette hubs are different than the F-Body.
”Sam Pace” hasn’t signed into the site since March 2020. If no response you could try sending an email or private message. Click on his screen name for those options.
Old May 13, 2022 | 03:30 PM
sam pace's Avatar
The difference between the 2 hubs goes as follows, 93-95 is longer. 96-97 is shorter due to reluctor ring. Reluctor ring plus 96-97 hub is the same length as 93-95. If you're doing a double roller conversion you need the 93-95 hub due to removal of reluctor ring.
Old May 13, 2022 | 06:28 PM
“Jason Paluszak” never came back to this site after his single post above. We both wasted our time trying to help.
Acct 23749
Parts Wanted
Jan 28, 2009 12:20 PM
SSTAT
Jun 11, 2007 01:19 AM
BMAN'S SCZ
Sep 13, 2004 08:32 PM
jtk
Mar 13, 2004 04:18 AM
brandboZ28
Oct 10, 2003 07:11 PM
