Crank hub question
Old Sep 13, 2004 | 07:39 PM
BMAN'S SCZ's Avatar
Crank hub question
The crank hub on our cars is balanced correct? Hellostop mentioned about drilling and tapping three holes in the hub and dimpling the crankshaft and holding it with three screws to stop the hub from spinning. As long as you drill right behind each hub ear you shouldn't affect the balance correct? It seems like it will work as long as it is symmetrical. Let me know what you guys think or know on this subject. Thanks....John.
Old Sep 13, 2004 | 08:04 PM
atljar's Avatar
Re: Crank hub question
Cranks are pretty soft metal, so i would think you would "strip" (lack of better work) the dimples out. I am assuming you are having blower slippage issues? Have you looked into keying the hub/crank?
Old Sep 13, 2004 | 08:26 PM
BMAN'S SCZ's Avatar
Well right now I just sleeved and keyed my crank hub after spinning it. But I was wondering if I can dowel it or do what I mentioned for added insurance without affecting the balance. Thanks for the reply though....John
Old Sep 13, 2004 | 08:32 PM
atljar's Avatar
Just giving my thoughts, but forgot to answer the question
The front hub and balancer are nuetral balanced. Good luck
HectorM52
Jul 30, 2017 11:46 AM
cyteone
Feb 7, 2015 06:04 PM
Chevyguy358
Jan 28, 2015 08:04 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
