Could this be causing my problems?
Old Oct 1, 2003 | 03:01 PM
HM Murdock's Avatar
While working on the opti, I noticed this out of the corner of my eye...Could this be causing my problems? I know it is probably a vacuum leak, which is what my problem is reminiscient of. Lousy idle, almost no vacuum, code 33 MAP high
Old Oct 1, 2003 | 03:04 PM
predator's Avatar
yep thats the vacumm canister if the hose is gone it will cause some probs like that
Old Oct 1, 2003 | 03:10 PM
HM Murdock's Avatar
And can you just remove it? This car has zero chance of passing an emissions test anyway.
Oh, and are there supposed to be 2 lines going into it? I can only find one...
Old Oct 1, 2003 | 03:21 PM
predator's Avatar
just fix the line it comes from where the lines for the ac controls are that has that little checkvalve on it
Old Oct 1, 2003 | 03:26 PM
HM Murdock's Avatar
OK, but there is only one line in the vicinity...And it looks like there are 2 openings...That's the question I have now...
Old Oct 1, 2003 | 03:34 PM
predator's Avatar
i dont think that is an opening i just thinl it is a locating pin or something because i only have one on mine also
Old Oct 1, 2003 | 04:06 PM
HM Murdock's Avatar
Yeah, I went and looked, and it does look like that. All I can hope is that it is the issue, cause I am going to put it all back together...
PCLZ28
Dec 24, 2015 05:19 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
GigaMp3z
Feb 20, 2003 02:57 PM
DarkHorse
Aug 3, 2002 10:17 PM
