Cost to replace LT1 plugs and plug wires
Old Jan 20, 2013 | 08:51 PM
  #16
slick1hunting's Avatar
Re: Cost to replace LT1 plugs and plug wires
How-to Route Over The Valve Cover Wires | Tech Aids & Articles
that shows pictures.
im pretty sure the ones the dealer used on mine a few years ago were ac delco and they had a lifetime warranty. might be worth a quick check.
ltcc is the coil setup. For me it worked great because i needed something to retard timing when spraying and I had 160,000 on my opti and was leary of putting my original back in with new motor,
6 and 8 arent to bad to replace the plugs taking starter off(2 bolts and a couple nuts with wires] but thats on mine with long tubes
quick heads up about the cut to fit wires. you would need lt1 style ends to put on the wires(i think i got mine from taylor) im not sure but i would bet the oe size for 8 would probably be long enough but I am not familiar with original routing
Old Jan 20, 2013 | 08:55 PM
  #17
1993-1997 LT1 F-Body Spark Plug Wires from Thunder Racing
Old Jan 20, 2013 | 10:33 PM
  #18
james96z28's Avatar
Thanks for the info and assistance.
Old Jan 21, 2013 | 03:05 AM
  #19
Chet1185's Avatar
I have a fresh rebuild ready to go in and that's what i'm buying from thunder racing, whole kit for $105
Posted from Camaroz28.com App for Android
Old Feb 25, 2013 | 02:49 AM
  #20
an84maro's Avatar
on my 1997 Z28 LT1......900$ is the same amount i was quoted by a chevy dealer in southern CA. I thought the price was outragous so i just took on the task myself. Knowing it was going to be daunting i waited untill i had a full 3 days to work on it so i didnt have to rush and could take my time one wire and plug at a time. Took probibly 10hrs total but got the job done and it runs like a champ. 900$ is alot but unless your going to do the job yourself then paying just any mechanics shop to do it for a little cheaper isnt good. They probibly have limited knowledge of the application and are in a rush to do the job so that means treating your car like s**t. I'd say just take it to the dealer. ...
Old Mar 2, 2013 | 08:32 PM
  #21
Matts97camaro's Avatar
Originally Posted by james96z28
Thanks to everyone for your replies. Can the wires be routed safely other than the factory way? Also, does the alternator, starter, water pump and power steering pump have to be removed to do this work?
Check these OVC sparkplug wire kit on my car. I have mid-length headers and they work great. Its about a 130 $ kit. You do have to crimp the spark plugs ends and cut to length, but they work great. Have had them on for a year + and no problems with wires arcing or making contact with the headers.
The kit is at Thunder Racing
I did not remove anything to install this kit. Very easy to do. Here is a video of what I did on my car.
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=2709& transactionid=1362277964-249978249&posted_by=Matts97camaro_www.camaroz28.co m&youtube_video_id=pgfHKweEsZ4[/autostream]
Old Apr 19, 2015 | 08:54 PM
  #22
nikko's Avatar
late to this post but about the coil per cylinder set up ..does this eliminate optispark
Old Apr 20, 2015 | 07:12 AM
  #23
You might want to start a new thread.... your question is unrelated to this thread.
Old Apr 29, 2015 | 12:16 AM
  #24
Midnight_Z's Avatar
$900 for plugs and wires lol, that's a raping they should go to prison for. Its tight quarters to change plugs and wires but a seasoned dealership mechanic should get it done in a few hours not 9 hrs. They would prob quote you $2000 to do a optispark! What a joke and a rip off some places are, makes me sick.
Old Apr 29, 2015 | 08:21 AM
  #25
You're responding to a post from 2 years ago. The person who posted the question hasn't been back to the site in 2 years.
The only reason this topic came back to the top was because someone recently decided to tack on a totally unrelated question.
Old Apr 29, 2015 | 10:05 AM
  #26
Midnight_Z's Avatar
Gotcha!
Jazsun
Dec 29, 2014 12:14 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
CobraEatr
Jul 29, 2002 11:46 AM
