compression ration, help me out?
Old Oct 21, 2008 | 11:11 AM
sn8ke eatr's Avatar
what would a piston with a .100 dome, stock head gaskets/valves/heads yield me as far as compression? i fear i may have used the wrong pistons
Old Oct 21, 2008 | 01:50 PM
bombebomb's Avatar
With a 3cc dome it put me at like 13.6:1. You need flat tops.
Old Oct 21, 2008 | 01:53 PM
rskrause's Avatar
Moderator
You need dome volume to calculate CR.
Rich
Old Oct 22, 2008 | 12:03 AM
sn8ke eatr's Avatar
compression ratio aside, would i run into major piston to valve problems? or would i be ok if a made some valve reliefs in the pistons?
would any type of aftermarket head be any better? i really really dont want to tear the motor completely back down, that is an absolute last resort.
Old Oct 22, 2008 | 09:20 AM
SS MPSTR's Avatar
heads with larger volume will help (i.e. TF with 64cc?). with a sane cam, there will be no pv issues. is the block decked?
Old Oct 22, 2008 | 11:23 AM
wrd1972's Avatar
13.6 to 1 CR.
Kaboom.
Old Oct 22, 2008 | 06:17 PM
SS MPSTR's Avatar
Originally Posted by wrd1972
13.6 to 1 CR.
Kaboom.
...at least on any fuel less than 110 octane.
Old Oct 22, 2008 | 09:00 PM
sn8ke eatr's Avatar
block is not decked.
so you think aftermarket heads with a larger combustion chamber would work with basically a le2 cam and my .100 domed pistons?
Old Oct 22, 2008 | 09:38 PM
rskrause's Avatar
Moderator
What is the dome volume?
Rich
Old Oct 22, 2008 | 11:46 PM
sn8ke eatr's Avatar
Rich
im actually not sure..
there .030 forged probes. i havent been able to find the part number to find out
edit* - they advistise these pistons as producing a cr of 11.24 using 64cc heads if that helps
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
HeavyChevySS
Advanced Tech
31
Mar 23, 2005 03:37 PM
