Battery ground to motor mount
Old Oct 22, 2008 | 11:39 AM
twcblackhand6970's Avatar
Is is okay to take the bolt off holding the ground on the motor mount so i can clean it. I'm having voltage gauge jumping everywhere and want to make sure it's clean, but don't know if taking that off can result in motor moving.
Old Oct 22, 2008 | 11:42 AM
MeanGreen97Z's Avatar
If you pull that bolt out... the motor is going to lean on you. You will need something to raise the motor a little while you take it out.
Old Oct 22, 2008 | 11:44 AM
If I just take the one out with the ground on it? There's two holding it in.
Old Oct 22, 2008 | 11:53 AM
dStruct's Avatar
Well do you want to support half your engine weight on a single bolt? Probably not a good idea, specially if you're going to be down there between the header and wheel working on it. I'd put a piece of wood and a jack under the motor to support it for sure!
Old Oct 22, 2008 | 12:01 PM
well, looks like it's going to have to wait another day. I've only got one, and it's holding my car up right now
Old Oct 22, 2008 | 12:07 PM
There should be no problem. It is a stud with a nut on top. You are taking the nut off. The part of it holding the motor mount on will not be disturbed.
http://shbox.com/1/battery_cable_ground.jpg
Old Oct 22, 2008 | 01:38 PM
Yea, whoever put the ground on, put it on the other bolt....
Old Oct 23, 2008 | 01:12 AM
dStruct's Avatar
Well that sucks man.. While you're checking grounds, have you looked at the braided ground line going from the driver side by the ABS computer over to the ICM block on the driver side head? The clip on that ground commonly breaks, I had to repair mine as I was getting a slight random misfire.
Old Oct 23, 2008 | 01:31 AM
no, where exactly is that one located? I cleaned one that I found behind bumper on the driver side. Now that I've cleaned all the grounds I could find except battery to block, pcm to block, and the other one the guy above mentioned, suddenly my throttle response is horrid. Like I'll press the peddle quickly and let off, and then my motor will rev.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
