compression q's
Old Jan 4, 2009 | 12:44 AM
87bandit's Avatar
compression q's
just wondering about what a couple different pistons would place me roughly compression-wise on a stock deck height non milled heads 355 lt1
+5.00cc flat tops with 2 valve reliefs
-4.00cc domed with 2 valve reliefs
also what's the average compression ratio you'd recommend on a daily driven lt1 with some nitrous here and there? (not often if at all most likely)
Old Jan 4, 2009 | 07:32 AM
bombebomb's Avatar
You do not want a domed piston, not sure what the compression will be, but with -3.00 cc dome my compression was way over 13:1, that was with heads milled .005 or so, block decked etc (forget actrual numbers). Most will agree to go with a flat top. For a compression I would maybe look at what the cam recommends. 11:1 is quite safe for a street car. I personally went higher (12:1) but 11:1 should do you fine, and leave you quite a bit of safe zone.
Also, nitrous does not mind compression.
Old Jan 4, 2009 | 09:00 AM
rskrause's Avatar
Moderator
There are a million CR calculators on the web, including on this site. As far as what CR you want, depends on the fuel used and the cam. In general, a small cam will want ~10.5:1 and`a big cam maybe as high as 11.5:1.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
