Compression ?
Old Aug 14, 2005 | 10:51 AM
  #16
FastZinTennessee's Avatar
Re: Compression ?
Originally Posted by 89385formula
Umm, am I the only one seeing that he is trying to run a milled head, 0 decked block, and a .029" head gasket? Try that calculation over with the thicker .039" head gasket.
I just caught that too. I wouldn't go lower than .035" on the quench, so the .039" headgasket should be ideal.
Old Aug 14, 2005 | 01:22 PM
  #17
93 4mula's Avatar
Re: Compression ?
Alright guys I really appreciate all the help yall have givin me. Heres what my DCR and SCR will be with the thicker gasket running all the same info but just thicker gasket. Quick question would the DCR increase if "VE" went above 100%? Also would I be safe spraying like a 250shot on this motor?
"With .039 Gasket"
DCR: 8:8:1
SCR: 12:6:1
Old Aug 15, 2005 | 12:08 PM
  #18
93 4mula's Avatar
Re: Compression ?
Anyone else?? Would I be safe spraying a 250shot on this motor with both compressions at what they are?
Eagle 4340 Forged Crank
Eagle H Beam Rods
SRP Flat tops -5cc
Old Aug 15, 2005 | 12:11 PM
  #19
89385formula's Avatar
Re: Compression ?
"With .039 Gasket"
DCR: 8:8:1
SCR: 12:6:1
I don't see why you would have a problem with a 250 shot, you would most likely want a set of 4 bolt mains, or splayed caps in order to do so. Also you would need to pull timing for the spray, and take other safety precautions but you already knew that i am sure. BTW, nitrous loves compression. Also with that high of SCR, and DCR....make sure you have a good cooling system.
Old Aug 15, 2005 | 12:15 PM
  #20
93 4mula's Avatar
Re: Compression ?
Yea thats another question I was going to ask, whats some ignition boxs yall would recommend looking at for timing? Give me a couple good ones so I can decide which one to get. With some of the boxs isn't it possible for the ignition box to pull the timing itself when the juice is activated?
Old Aug 15, 2005 | 12:19 PM
  #21
Re: Compression ?
The box I will be using for spray is the Mallory 685 box, it has alot of options. It has a single stage timing retard, a window switch and I believe it is digital. Its very reasonably priced as well. The only other one that I would consider in that price range is the MSD digital 6, but its more money and has no window switch. Both can be wired up so they pull timing when the spray is activated.
Old Aug 15, 2005 | 12:35 PM
  #22
93 4mula's Avatar
Re: Compression ?
Yea I think Im going to get the Mallory box especially since it has a built in window switch I really like that. Dont you pull timing 2 degrees every 50hp?
Old Aug 15, 2005 | 12:37 PM
  #23
Re: Compression ?
Its recomended that you do, but I think thats if you are VERY precautious. Alot of people pull that much after 100 shot, but nothing b4 that.
Old Aug 15, 2005 | 06:14 PM
  #24
93 4mula's Avatar
Re: Compression ?
So if I was to spray that 250 shot Id pull the timing 10 degrees?
Old Aug 16, 2005 | 06:21 PM
  #25
arnie's Avatar
Re: Compression ?
... would the DCR increase if "VE" went above 100%?
Speaking of VE... Also, before you finalize your numbers, the following link should put
a dent in your confidence in DCR calcs. It looks at DCR from a very different perspective.
http://victorylibrary.com/mopar/cam-tech-c.htm
Old Aug 16, 2005 | 09:26 PM
  #26
rskrause's Avatar
Moderator
Re: Compression ?
I would talk to SRP before spraying a 250hp shot on those pistons.
Rich
Old Aug 16, 2005 | 10:04 PM
  #27
arnie's Avatar
Re: Compression ?
I don't consider a .039" quench clearance "ideal" using any stretch of the imagination. As long as he doesn't rev over 8 grand with a real 'rocky' piston, he'd be alright with the .029" quench clearance. No sweat. Ideal? I'd go with .030-.032" as 'ideal'.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
