Fuel in oil
Old Aug 16, 2005 | 08:33 AM
cb94ta's Avatar
Fuel in oil
I've got fuel in my oil where could it be coming from, oil pressure is still okay but now i'm worried, car has run like hell lately a backfire every once in a while, has trouble reving past 2500 rpms, just has no power any ideas?
Old Aug 16, 2005 | 01:02 PM
RE AND CHERYL's Avatar
Re: Fuel in oil
Have you been getting worse than normal gas milliage too?
Sounds like the diaphram in the fuel pressure reg has ruptured and is allowing gas into the engine through the vacume line. When you shut off the engine the excess pressure runs into the cylinder with an open valve, past the rings and into the oil. Pull the vacume line with the engine running, I'll bet gas will be comming out of the regulator.
Old Aug 16, 2005 | 10:08 PM
cb94ta's Avatar
Re: Fuel in oil
gas mileage has gotten worse tomorrow morning I'll pull the line thanks for the tip.
HectorM52
Jul 30, 2017 11:46 AM
Cam's maro
Mar 24, 2015 08:09 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
Wilson
Aug 20, 2002 10:36 AM
