Come on guys, which CAI?
Old Sep 25, 2006 | 10:40 PM
  #16
RKPsk8er's Avatar
Re: Come on guys, which CAI?
I have a moroso CAI with a K&N filter. it works really nicely
Old Sep 25, 2006 | 10:44 PM
  #17
HardcoreRM125's Avatar
LS1 lid retro-fit is a majr pain in the nuts.
The best CAI, really, would be a Ram Air hood ( TA Style, not SS ) and a good filter. Its the straightest, highest flowing, intake path. Take a look at Injuneer's pics and you'll see what I mean. He also debaffled the ram air.
But really, your only gaining a couple horsepower going that route over a regular, big-name brand CAI. But if you plan to build any kind of blower/turbo car, ever, dont waste your time and money. Just buy a CAI, used on the board, use it until you go forced induction, and then sell it back on here for what you paid.
Old Sep 25, 2006 | 11:12 PM
  #18
White95LT1's Avatar
Anyone elses SLP CAIs not fit like it was supposed to?.....I mean I love my SLP CAI....but the lil bracket that's supposed to slide into place on the stock Filter box location is about an 1/8" off..
Old Sep 25, 2006 | 11:16 PM
  #19
Z95m6's Avatar
Originally Posted by Z28Roxy
Homemade. Then you can use the biggest filter that K&N or a similar company makes.
Also, you can make the pipe diameter larger than the premade ones.
What good does that do? you can only flow as much air as the 3in MAF allows.
Old Sep 26, 2006 | 06:41 AM
  #20
THEBEAST94TAGT's Avatar
Is the 1LE elbow the best flowing elbow? All these trick flow and vortech elbows are metal and after a while will soak up a bunch of heat and increase your intake air temp, thus hurting power. The 1LE is at least rubber, any one got other ideas on this?
Old Sep 26, 2006 | 08:58 AM
  #21
Each component of the air flow channel contributes to the total pressure loss in the system. Improving any single component can increase the air flow, if it reduces the total pressure loss. The system flow is not dependant only on the smallest component (although that component offers the largest opportunity for improvement). A larger filter, a larger diameter intake tube, less bends, smoother bends, etc. all reduce pressure loss and increase the density of the air that fills the cylinder.
Old Sep 26, 2006 | 09:31 AM
  #22
micfly83's Avatar
I got my ebay intake
Works great
Came with a K&N filter that came in an actual K&N box.
Essentially its all the same, its a 3" tube going deep into the front fender, and it stays pretty cool.
The only downside is that there isn't any mounting brackets, but its sitting on a bunch of stuff and its already pretty rigid, so really its no problem at all.
I'll save my $100 and spend it on somethin else.
ModdedNerd
Feb 5, 2015 04:37 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
troywg
Sep 12, 2002 07:28 PM
Red97LT1
Aug 7, 2002 05:45 PM
