Come on guys, which CAI?
Re: Come on guys, which CAI?
LS1 lid retro-fit is a majr pain in the nuts.
The best CAI, really, would be a Ram Air hood ( TA Style, not SS ) and a good filter. Its the straightest, highest flowing, intake path. Take a look at Injuneer's pics and you'll see what I mean. He also debaffled the ram air.
But really, your only gaining a couple horsepower going that route over a regular, big-name brand CAI. But if you plan to build any kind of blower/turbo car, ever, dont waste your time and money. Just buy a CAI, used on the board, use it until you go forced induction, and then sell it back on here for what you paid.
Anyone elses SLP CAIs not fit like it was supposed to?.....I mean I love my SLP CAI....but the lil bracket that's supposed to slide into place on the stock Filter box location is about an 1/8" off..
Originally Posted by Z28Roxy
Homemade. Then you can use the biggest filter that K&N or a similar company makes.
Also, you can make the pipe diameter larger than the premade ones.
Is the 1LE elbow the best flowing elbow? All these trick flow and vortech elbows are metal and after a while will soak up a bunch of heat and increase your intake air temp, thus hurting power. The 1LE is at least rubber, any one got other ideas on this?
Originally Posted by Z95m6
What good does that do? you can only flow as much air as the 3in MAF allows.
I got my ebay intake
Works great
Came with a K&N filter that came in an actual K&N box.
Essentially its all the same, its a 3" tube going deep into the front fender, and it stays pretty cool.
The only downside is that there isn't any mounting brackets, but its sitting on a bunch of stuff and its already pretty rigid, so really its no problem at all.
I'll save my $100 and spend it on somethin else.
Works great
