Code p0412
Old Jan 4, 2019 | 10:29 AM
Brad Minick's Avatar
Code p0412
I have a 97 z28 Camaro. Was running fine. All of a sudden it started running rough upon acceleration .Hesitation really bad .code p0412 came up .which is secondary air injection system switching valve a circuit .Pevious owner removed air pump .I looked at fuse. And was good .but there is not an air pump relay in fuse box .any thoughts on why all of a sudden my car is acting up? Thanks in advance .
Old Jan 4, 2019 | 04:09 PM
Re: Code p0412
I'll move this to "LT1 Based Engine Tech" where you are more likely to get help. Podcast isn't the right place.
DTC P0412 is "AIR Relay Control Circuit", per the factory service manual. The diagnostic checks the AIR pump relay control circuit to see if the voltage matches the commanded state (on or off). If the relay is missing, the code will set. Replace the relay.
Old Jan 4, 2019 | 04:12 PM
Re: Code p0412
Do I have to clear the code? Or will it clear it self?
Old Jan 4, 2019 | 04:29 PM
Re: Code p0412
Thanks for your help.
Old Jan 4, 2019 | 04:32 PM
Re: Code p0412
It will eventually self-clear. If you don't have a 2-way scanner (read/clear), pull the "PCM BAT" fuse for 30 seconds.
Shaun Quill
Aug 18, 2009 07:56 AM
99BlackTA
Nov 13, 2004 01:10 PM
steven 95z
Oct 23, 2003 08:01 PM
Alan566
Jun 11, 2003 11:14 PM
jimmytt6
Apr 3, 2003 10:04 AM
