Code 29 air pump quit
Is there any way around running an air pump? Can you bypass it or fool the pcm that its working? It keeps blowing the fuse and turning the serv. engine light on.Thanks.
Where was this fuse located? I only kept the under hood fuse box and only use the injector and fan fuses there, is there a wire and Pin# on any of the 4 ECM connectors I should put a fuse on to get rid of this code? is this to ground or from a switched or non switched 12V?
Thanks,
Greg
I have a swapped LT1 in a Datsun and have a code 29, I have no air pump.
Thanks,
Greg
Thanks,
Greg
Dam! I think I deleted the wiring for that, I'll check tomorrow.
What pin/pins on what color ECM connector should I fuse if I did delete the wiring from the fuse block?
That might explain the always on SES light... Aside from the code 43 I also have to trace out.
Thanks Shoebox, I was just at your site and pulled up the same diagram,
so on the Red "A" connector pin A14 is the ground side of the Air pump relay, couldn't I measure the impedance of the relay coil and substitute a resistor of the same value?
Or do think it is safer to just hang a fused relay? The relays have a diode across the coil on the inside?
Thinking ahead here, If I didn't remove the wiring all is good, I am sure I tossed the relay into my relay collection box and will simply find it and plug it and the fuse back in.
Thanks again,
You site has always helped my son and I out, I have the LT1 Datsun 280Z and he has a 95 Formula.
Greg
Greg
Thanks again,
Greg
Greg
Thanks again,
Greg
Greg
Thanks again,
Greg
Greg
Will a resistor work?
Thanks,
Greg
Don't know that a resistor will work. You could try, but I'm going to guess you will need to duplicate what the original schematic shows (relay and fused power). Or you can just have the trouble code programmed out.
CamaroZBoy
Sep 9, 2002 10:33 AM
CamaroZBoy
Sep 1, 2002 09:48 AM
