Code 29 eas electrical fault???
Old Jun 11, 2003 | 11:02 PM
Alan566's Avatar
Thats what the scanner says. I did a search and all i could find on here CODE 29 (AIR PUMP/RELAY). But mine says eas electrical fault. Its on a 95 Z OBD 1. Thanks Alan
Old Jun 11, 2003 | 11:14 PM
DTC 29 = AIR pump circuit. 9 times out of 10 it means the fuse for the AIR pump is blown. If you replace the fuse and it continues to blow, there's a good chance the pump is siezed up, or about to sieze up. You can just unplug the harness connector from the pump, and make sure there is a good fuse in the circuit, and the code and light will go away.
markzzzz
May 8, 2015 09:21 AM
May 1, 2015 01:14 PM
Gtpguy
Jan 26, 2015 04:50 PM
91Bird305
Aug 8, 2002 12:36 AM
91Bird305
Aug 5, 2002 01:39 PM
