Code 63 on 94Z
Old Apr 27, 2011 | 10:36 PM
Yenkohead's Avatar
Code 63 on 94Z
I took my Camaro to a shop and they told me that I have a code 63 and suggested that the pass. side O2 sensor is either bad or has issues with its wiring. Anyone familiar with this code number? Some helpful history:
I replaced the orig exh manifolds awhile back and swapped over the orig O2 sensors. I also have replaced the cat converter and y-pipe. I also have recently replaced the stock intake elbow. Car is a stock 94Z with 189K miles and a rebuilt transmission.
Any help would be greatly appreciated.
Thanks,
Greg
Old Apr 27, 2011 | 10:45 PM
Re: Code 63 on 94Z
Like they said:
63 Bank 2 (right) Heated Oxygen Sensor (HO2S) Circuit (open circuit)
Wiring or O2 sensor. If you were to swap the sensors from side to side, that might tell you something (if trouble follows the sensor or not).
Old Apr 28, 2011 | 10:18 PM
Yenkohead's Avatar
Re: Code 63 on 94Z
Thanks Shoebox. I feel more confident now hearing it from two diff sources. I just bought the O2 sensor removal tool and am pricing O2 sensors (quoted $60 so far). Guy at NAPA said that there is only one brand available (Bosch, I think). He said if I look at the original it is probably from Bosch. Sound right? Any other sources, or anyone know where I could pay a reasonable price for a GM sensor?
Thanks,
Greg
Old Apr 28, 2011 | 10:35 PM
Re: Code 63 on 94Z
No, you want to get some AC-Delco O2s. Bosch was not original equipment and don't seem to work well with the LT1 for some reason. Search the web. You can find some.
Old Apr 29, 2011 | 05:21 AM
Re: Code 63 on 94Z
Did you check the wiring first?
Old May 17, 2011 | 11:09 PM
Yenkohead's Avatar
Re: Code 63 on 94Z
Sorry, it took awhile to get this figgered out. It turned out that the metal clip that is attached to the wiring for the O2 sensor was not seated tightly. I simply slid the clip tightly onto the O2 sensor and the car runs like a champ again!
Thanks all!
Greg
kksi
Mar 21, 2015 09:03 PM
mschmidt33
Mar 15, 2015 07:20 PM
stopthatman
Feb 9, 2015 09:00 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
