Code 29
Old Apr 12, 2003 | 04:41 AM
crawl96's Avatar
Question Code 29
I'm throwing a 29 code air circuit.. what doesn't it mean. anybody had this problem? Air pump is 1 1/2 olded.
Old Apr 12, 2003 | 08:47 AM
97 SLP Company Car's Avatar
Ive had that one, it means your air pump is either dying(shorted) or dead.
Old Apr 12, 2003 | 10:19 AM
crawl96's Avatar
Code 29
after the car warms up the service Engine Led comes. Have friend with a code reader and comes up with code 29. Seem when you first crank the car everything looks fine. did you have the same symtom?
Old Apr 12, 2003 | 10:40 AM
9 times out of 10, DTC 29 means the fuse for the AIR pump is blown. Check it. If blown, replace it. If it continues to blow, the AIR pump is rusting up and drawing too much current, or the wiring is screwed up. A temporary "fix" is to put a good fuse in the curcuit, then unplug the harness connector at the pump (this only avoids the SES light/code in OBD-I, 93-95).
Then check your pump. A leaking check valve... the black conical gadget on top of the exhaust manifolds.... will allow wet exhaust gasses to back up into the pump and corrode it. Just one possible cause.
Old Apr 13, 2003 | 05:37 AM
crawl96's Avatar
You nail the problem, blown fuse. damn I thought I checked it. I’m blind sometimes. But thanks the for infor. I was wondering if you might know why I'm having slight
Surge on acceleration? I replaced the MSD wire with Taylor same problem, Plugs are about 7months old. NGK TR55. would you have any picks to bypass EGR? Dude thanks bunch..
Darren
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
