Code 18 crank senso open/ no signal
Old Aug 8, 2005 | 02:29 PM
Warlock1313's Avatar
Question Code 18 crank senso open/ no signal
Hi , I have just recently got a 94 z28 and was pulling codes found code 18 for the crank sensor, the vehicle runs good, however intermitently will have a long crank time.
Is this a bad opti?? (replaced at dealer 'bout a year ago)
anyone have a diag proceedure??
THX
Old Aug 8, 2005 | 04:08 PM
Re: Code 18 crank senso open/ no signal
DTC 18 Injector circuit(s)
There is no separate crank sensor on a 1994.
You need to check the fuses and wiring to your injectors and check their resistance, if needed.
Old Aug 8, 2005 | 07:32 PM
thats interesting because my snap on scanner states it is the crank sensor no signal/ open ... where can I find a dtc list and complete wiring diagrams (web)???
Old Aug 8, 2005 | 07:55 PM
Dave89IROC's Avatar
on shoebox's site
http://shbox.com/1/4th_gen_tech1.html
Old Aug 8, 2005 | 07:58 PM
ok I have to dtc list, so if it is the injectors can I use my extra 30#ers with the stock maf or do I need a new one?
Old Aug 8, 2005 | 10:27 PM
I would not consider swapping any injectors until I did some troubleshooting to see what the trouble really is.
Changing the injectors does not mean you have to to anything to the MAF. Some reprogramming for the different injectors would be good, though.
A link to the DTCs is right in my sig.
Old Aug 9, 2005 | 06:01 AM
slopokrodrigez's Avatar
Yeah my CGS from Snap-on said the same thing. Remember that OBDI's don't have a crank sensor.
The first thing you want to do is reset it and see if it returns. Check the 2 fuses. Now pop the connectors off the injectors one at a time and then replace them until you find one that does not change the idle quality. If that happens measure the resistance of the injector to be sure it is not lower than 11.6 ohms and is also not open either. Then check the signal with a noid light.
If you need it, I can scan and email the injector circuit schematic to you cause I think the internet source of diagrams has dried up.
Old Aug 9, 2005 | 08:19 AM
Says who?
Old Aug 9, 2005 | 11:07 AM
so is this code triggered by a failure on the electrical side of the injector , or will it set this code for a leaking injector also??
Old Aug 9, 2005 | 11:44 AM
It is an electrical fault.
Old Aug 9, 2005 | 04:07 PM
Originally Posted by shoebox
I SIT corrected. there is always good o'l shoes pages.
I was refering to the wonderful EBSCO look up we all used to use before they got wise to us.
Klypto
Mar 23, 2016 09:05 AM
ad356
Apr 11, 2015 11:12 PM
Lions3
Apr 11, 2003 10:55 AM
91Bird305
Aug 5, 2002 01:39 PM
squirrels
Jun 10, 2002 06:05 AM
