Spark from ground????
Old Aug 8, 2005 | 09:32 PM
BLDun's Avatar
I have the setup in my sig. The electric water pump relay is grounded on the front frame that passes under the radiator shroud. In the course of chasing down a miss I was cleaning all the grounds I could find. When I unscrewed this ground screw and pulled the wires off there was a spark. So just to make sure I replaced a couple of times and took it off and it did it every time. Upon further investigation I realized I had left the switch key on. When I turned it off there was no more spark. Question is even with the key in the on position should there be a spark at all at this location??? Or is this indicitave of a further problem???
Thanks for any help
Old Aug 9, 2005 | 01:37 PM
BLDun's Avatar
Re: Spark from ground????
ttt
Old Aug 9, 2005 | 04:07 PM
If your relay is wired so that it operates with the key ON, then you would get a spark in the conditions you described. There is no problem.
sleeperZ96BT
Sep 9, 2015 08:28 AM
War Engine
Aug 20, 2015 06:13 AM
4586
Aug 18, 2015 07:08 AM
cmsmith
Aug 9, 2015 07:30 PM
realistyc
Jul 28, 2015 07:32 PM
