Cloyes Crank Gear Is Thicher Than The Stocker
Old Apr 9, 2007 | 11:37 AM
turnin20s's Avatar
I ordered a cloyes double roller timing chain and after I got the stock crank gear off I measured the difference between them and the cloyes gear is about 1/10"? thicker than the stock gear.
Will this be ok or should I take it to a machine shop and have it turned down a little bit?
That measurement might not be right, I did it a couple days ago but I'll go out and check it again to be sure.
Old Apr 9, 2007 | 12:00 PM
89TramsAmGTA's Avatar
Will not the crankshaft pulley be out of aline if he does not turn down the sprocket?
Old Apr 9, 2007 | 01:37 PM
turnin20s's Avatar
I actually went out today and the back of the cloyes gear is inset so it doesn't put the pulley out of alignment, I didn't notice that before when I measured it.
I can't measure it since my caliper won't fit inside of the hole, but I think it will be ok, but if not I'll find out when I get the car running.
Anyone else have any experience with this? Does it space the pulley out at all? Let me know if you can
Old Apr 9, 2007 | 02:20 PM
JP95ZM6's Avatar
I understand from what I have read that going to a double roller requires slight clearancing of the timing cover. Might search that. I doubt if turning the sprocket would help unless that is the widest part, but I think the chain is wider.
Old Apr 9, 2007 | 02:26 PM
turnin20s's Avatar
Yeah I know about clearencing the cover, but I thought that I would have to have the crank hub turned down a few thousands to keep the belt in line, but it looks like it will be ok.
I haven't gotten around to the cover yet, but I will as soon as my motor comes back from the machine shop and I start the reassembly. I'll take some pics of what I had to do since I haven't found any pics of it yet.
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
1LEThumper
Jul 14, 2003 12:45 PM
