Chomemoly or Cold Forged Pushrods?
Old May 11, 2004 | 10:33 AM
  #16
WS Sick's Avatar
I recently changed from the comp cams 3 peice hardened steel pushrods to the CM trickflows and notices a little valvetrain noise go away. I initially did the change because I bent a few Pushrods and didnt want to risk that again. The old pushrods I took out after inspection revealed that almost all of them that a slight bow to them , it was unnoticable unless I rolled them on a flat surface. My spring pressure open is a little over 430 #s open and 165 #s closed. The Comp hardened steel ones worked fine with my previous springs for years (I did buy a new set though when I went to the nes springs to be safe). The bent pushrods had a little over 2000 miles on them. I think the valvetrain noise was from the pushrods flexing and rubbing in a few places.
Old May 11, 2004 | 10:40 AM
  #17
CrAkD X 95TA's Avatar
not to jack the thread but i cant see making a new thread for basicly the same question
im doing a rebuild with a hotcam kit and comp R lifters what size/type of pushrods should i get?
Old May 11, 2004 | 10:42 AM
  #18
WS Sick's Avatar
You'll do fine with the comp steel 3 peice hardened ones, as long as you keep your open spring pressure at 350 or less.
Old May 11, 2004 | 02:15 PM
  #19
Xride's Avatar
I got the crane dual springs.... so I'll go chomemoly.
Old May 11, 2004 | 02:35 PM
  #20
Mindgame's Avatar
Originally posted by tnthub
Doesn't chromoly tend to crack in street applications?
Your probably thinking about welded chrome-moly components like a-arms. There was some talk in this forum on that some time ago. Chrome-moly structures are as good as their welds.
Those of you running guideplates, make sure you get hardened PR's.
-Mindgame
Old May 12, 2004 | 05:04 PM
  #21
TedH's Avatar
So with a 236-242 cam, stroker, 1.6 rr's, and the fact I broke two pushrods last weekend, and bent/broke three last season, what should I order overnight for this weekends race?
Old May 12, 2004 | 06:34 PM
  #22
1 Nasty Bird's Avatar
if you want some badass custom to order (but they can get em out the door real quick if you need) try www.mantonpushrods.com
They can make you a pushrod thatll hold up the titanic if you want
Quickss96
Jan 29, 2016 05:56 PM
Cbr02
Aug 24, 2015 07:12 AM
alphaauto
Jul 26, 2015 04:40 PM
94Form
Jul 17, 2015 10:56 PM
Catmaigne
Jul 14, 2015 05:17 PM
