Chatter from around plug 8? help me!!! IS IT DYING???
Old Jan 14, 2006 | 06:05 PM
Critter's Avatar
Angry Chatter from around plug 8? help me!!! IS IT DYING???
i know i have an exhaust leak on the passenger side. today i started the car up and was under hood. i reved it a little from the tb to listen to the exhaust leak.... then i hear a chatter when it reved down from around plug 8. only when it reved down from higher rpm ...(around 3000 i would guess) almost sounded like a diesel idle type chatter.
1. exhaust leak (possible crack in manifold?)
2. lifters? rocker arms
3. something internal? (maybe rist pin?)
keep in mind i have 188,000 miles
i know i need to rebuild regardless... just don't have that kinda $$$. shot me some theorys plz.
Old Jan 14, 2006 | 07:26 PM
GreenDemon's Avatar
Re: Chatter from around plug 8? help me!!! IS IT DYING???
A compression check will settle most mechanical issues. The plug should let you know if you're getting fuel & spark. If it seems ok, it's possible you could have an exhaust leak. It also wouldn't be a bad idea to get a piece of hose and listen around under the hood. A lot of noises can be deceiving down there.
Old Jan 14, 2006 | 07:31 PM
valter's Avatar
Sounds like a loose rocker to me.
Old Jan 14, 2006 | 08:25 PM
Critter's Avatar
i know that its getting spark and fuel so that ones ruled out
Old Jan 24, 2006 | 05:09 PM
Critter's Avatar
i don't think its the rockers...
cracked manifold? now it has blueish white smoke!!!
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
andrewcapps82
May 19, 2015 10:11 PM
charchri4
Apr 14, 2015 06:40 PM
grabbem88
Mar 18, 2015 01:25 PM
Scottyboy
Feb 11, 2015 10:28 PM
