Changing my head gasket.. couple q's
Old Feb 13, 2011 | 11:11 PM
  #31
RamAir95TA's Avatar
Re: Changing my head gasket.. couple q's
Torque pattern is identical to SBCs, working in a circle from the inside-out.
ARP head bolts can be reused.
Old Feb 14, 2011 | 12:30 AM
  #32
Larsv8's Avatar
Cool thanks
Old Feb 16, 2011 | 11:24 AM
  #33
350350's Avatar
Originally Posted by shoebox
... The steam pipe washers can be had at most auto parts stores, but are usually called oil or a/c seals and much cheaper than the GM part.
Wanted to x2 this issue, I had a really hard time finding the steam pipe washers. Went to 3 parts stores before the NAPA guy finally just went through boxes of drain plug washers to find a match. Looking them up by the Camaro application got me nothing.
So go to the parts store you go to when you need the parts person to actually know something about cars...
Old Feb 16, 2011 | 11:27 AM
  #34
350350's Avatar
And, also, my Fel-Pro complete head gasket set had every other seal, gasket, and o-ring, except these steam pipe washers.
Old Feb 18, 2011 | 09:40 AM
  #35
Randy_M's Avatar
What is the general opinion for using Fel-Pro head gasket #1074 when rebuilding the engine and replacing the head gaskets? I am somewhat new with the LT1 in the C4 Corvette's and want to make sure I use the best. Since there seem to be several different part number for these head gaskets, I am not clear on this but own a pair of 1074's and would like to use them if possible.
Old Feb 18, 2011 | 10:39 AM
  #36
They are used often by many people.
DirtyDaveW
Dec 1, 2016 05:37 PM
parkers Z28
Mar 11, 2016 08:14 PM
blac94Z
Feb 18, 2015 11:36 AM
xmatt
Sep 16, 2002 02:37 PM
