Stereo ? -- LT1
Old Sep 6, 2002 | 06:15 PM
xmatt's Avatar
Question Stereo ? -- LT1
What is the most power I can get out of my stock 94 6.5" bose sub? I changed the head unit and have to buy an amp, but am on a limited budget so getting one that is too much stronger than the sub can handle is pointless.
Longhorn...driving a '94 Z-28 w/t-tops
-6 speed
-Borla Catback
-K&N CAI
-Hurst Short-Shifter
-Centerforce Dual-Friction Clutch
-Eibach Pro Springs
-SFCs
-TB Bypass
-Hypertech PP+
-160* Thermo
-Slow *** passenger window
Old Sep 6, 2002 | 07:04 PM
FastZinTennessee's Avatar
Post
I don't understand why you have to buy and amp now Believe me, I used to install at circuit city and now I do it at a custom shop, and as an ex owner of the bose system The radio will wire directly in and all the speakers will still play. They will be loud because in effect you are double amplifying the speakers. Otherwise I would not put any other amp to that 6.5, it will blow. It is not designed to handle any more power than the bose amp can push.
If you run into any more problems or questions e-mail me Fastzntn@aol.com
John
1995 Camaro Z28 A4 3.23
K&N CAI, Airfoil, Meziere H2O Pump, SLP Headers, Off-Road Y-pipe, Flowmaster Force II, 1LE Driveshaft, Energy Suspension Trans Mount, 1LE induction elbow, !MAF, !TB, !AIR, !EGR
Is that an LT1 under the hood or are you just happy to see me?
Old Sep 6, 2002 | 07:41 PM
xmatt's Avatar
Smile
Thanx man..I will try and figure it out. I just bought the car and hope that your plan works. I will let you know how it goes.
-6 speed
-Borla Catback
-K&N CAI
-Eibach Pro Springs
-SFCs
-TB Bypass
-Hypertech PP+
-160* Thermo
Old Sep 6, 2002 | 09:23 PM
clb95z28's Avatar
Post
I would recomend buying a head unit to bose adapter and wiring your system the way it is stock. Don't buy another amp by any means!The bose system in these cars is fairly decent. If you want it done by a professional, go to a car stereo shop and have them solder it all up for you. I had the same exact thing done to my car, Head Unit > Bose back in January. I had it done by the stereo shop manager named Jeremy at the Circuit City on Brodie Ln in South Austin. He did an excelent job and I would recomend him to anyone in a similar situation. If the previous owner had the speakers running off of an aftermarket head unit and not the bose amp, you have to connect all the wires the way they originally came to make it all work correctly. I also have personally had to do this on my car. Shoot me an email if you need any help with it. It's not my first rodeo!
Cody
BTW glad to see a fellow Horn on the board!
Old Sep 7, 2002 | 09:59 AM
Brent94Z's Avatar
Super Moderator
Cool
<font face="Verdana, Arial" size="2">Originally posted by FastZinTennessee:
John
</font>
Amen! I have done the above on several 4th gen cars and it works great. Not as good as a completely upgraded stereo system but it works pretty good. So often when I tell people they can replace ONLY the head unit and use a $4 Wal-Mart wiring adapter, I'm told it can't be done and the expensive "Bose wiring adapter" is required. I reply back with "interesting because my aftermarket head unit is working fine in my Camaro"
The only thing you have to remember is you must connect the power antenna wire to the switched 12v supply or you won't get any sound out of the speakers
Since this is getting more into the custom stereo end of it, I'll move it to the Custom Car Audio forum
Brent Franker * Main Page
94 Vortech Z28 * 96 Z28 SS #1655 & #259
4th Gen Appearance Modification Guide
F-Body Install & Fix-It Guides
Old Sep 16, 2002 | 02:37 PM
xmatt's Avatar
First, thank you cody for looking at my set-up.
Second, we determined that b/c I am all aftermarket except for the sub (I have a Panasonic Head unit and 4 infinity speakers), that i still need an amp. Brent, or anyone else, suggestions??
~Matt
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
