changing the alternator
Old Jul 27, 2003 | 10:49 AM
chevyboy_z28's Avatar
yesterday i found out that the reason my car died was b/c my alternator was bad and it killed my battery, so i replaced both. im in the process of putting the new alternator in but i cant seem to work the belt up over the pulley (theres not enuf slack ). is there a tensioner or something i b/c this m/f aint budging?
Old Jul 27, 2003 | 10:59 AM
joeSS97's Avatar
Yes there is a tensioner.You have to go under the car.I believe its a 15mm.
Old Jul 27, 2003 | 11:04 AM
AsianSensation's Avatar
You will need a 13mm socket. See pic below. I like to slip the belt over the tensioner pulley last while other like to put the belt over the crankshaft balancer last while releasing the tension on the pulley.
Tensioner
Old Jul 27, 2003 | 11:57 AM
i dont understand, i unloosened the tensioner bolt, and tried to see if that would give me any slack and it didnt, so i took the whole tensioner off and now the belt fits over the alternator, but the dam tensioner is off . how are you supposed to do this. on your diagram it says and the belt just fell right off. well mine didnt come off until the whole tensioner was off. somebody please explain?
Old Jul 27, 2003 | 12:03 PM
The tenioner rotates to give you slack, you have to put some muscle behind it to give a lot of slack. Taking the bolt off on the tensioner is the wrong way to do it.
Old Jul 27, 2003 | 12:33 PM
shox9879's Avatar
gm parts
hope you buy gm parts from the gm dealer i bought a alternator from pepboys went on a 500 mile trip changed it twice on the way bought a gm part never went bad agian
Old Jul 27, 2003 | 02:31 PM
Tensioner. As you crank clockwise, the tensioner will swing and give you slack. You don't take the pulley off.
DirtyDaveW
Dec 1, 2016 05:37 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
eanhl2004
Apr 4, 2015 12:01 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jul 4, 2005 05:00 PM
