Ceramic or Jet Hot, difference??
Old Jan 7, 2004 | 12:37 AM
Shue97_Z28's Avatar
Im buying Hooker LT's and Im just curious as to what the difference is between Ceramic coating and Jet Hot coating, is the name the only difference?
thanks in advance.
Old Jan 7, 2004 | 02:58 AM
InjectedSS's Avatar
Re: Ceramic or Jet Hot, difference??
thanks in advance.
They are the SAME THING.. Both are $250 of worthless coating for a pretty header
Old Jan 7, 2004 | 03:10 AM
QCKZ28's Avatar
Re: Re: Ceramic or Jet Hot, difference??
explain why you think this.....
Old Jan 7, 2004 | 03:18 AM
chesee48's Avatar
i think coating of headers is a very good and wise investment for a set of headers that u plan on keepin for a good amount of time on the car....IMO
Old Jan 7, 2004 | 03:27 AM
QCKZ28's Avatar
it doesnt take very long in VA weather for non-coated headers to start looking like rusted manifolds, every person i have talked to that bought non-coated headers wish they had bought coated ones.
Shue97_Z28 the coatings are basically the same. you should check out www.jet-hot.com for some info on ceramic coating.
jesse
Old Jan 7, 2004 | 10:03 AM
LWillmann's Avatar
My LTs were coated by Paul Berry (or is it Barry?)...
The guy that originally owned mine had them coated by him when new, he ran them for three years and had them recoated (no charge, only shipping costs) before I bought them. They look NEW, with the minor exception of some minor dings and scratches from the previous owner.
Coating is a wise investment IMO.
Old Jan 7, 2004 | 10:57 AM
doodad's Avatar
Coating is a good thing. Stick your hand on an uncoated header a few minutes after shutting the car off. You can with coated headers. And you won't burn out your heater box.
Old Jan 7, 2004 | 11:05 AM
Cera-metallic coatings go far beyond being "pretty".
-significantly reduced under hood temperatures, less melted parts and burned wires, less heat soak on intake, etc.
-reduced corrosion - they don't rust from the "weather", its from 1200deg+ tube metal temperatures
-reduced stress cracking from heat cycling and vibration
-power gains up to 3% due to improved scavenging from higher temperature exhaust gasses
-look "pretty"
Old Jan 7, 2004 | 04:23 PM
InjectedSS's Avatar
Alright, wait for a year or so and see that they will start to fade anyways. My buddy has his long tubes coated and now he wishes that he never would have WASTED $250 for that crap
Old Jan 7, 2004 | 04:29 PM
I don't have to "wait for a year or so"..... I ran a set of JBA's for 3 years with my bolt-on setup, coated by Airborn, and they looked absolutley like new, nice satin aluminum finsih when I sold them. Got top $$$ for them.
I replaced them with a USED set of AS&M's with HPC coating, and now that the headers are 6 years old, and have seen close to 900HP on the previous engine, and 800HP of nitrous on mine, they are getting a little "dull"... but still look pretty good, still keep the heat in the tubes, still aren't cracked, etc.
"CRAP" seems to be your opinion of everything.
AS&M's after 2.5 years on a 9-sec., 30th SS......
JBA's after 2.5 years.
Old Jan 7, 2004 | 09:15 PM
$hawn's Avatar
Your supposed to wash/clean them every once in awhile. Might be some peoples problems.
Old Jan 7, 2004 | 09:26 PM
ibanez6rg's Avatar
Coated headers look 10x better after longer periods of time and they keep the engine bay a notch cooler. My y-pipe is also Jet-Hot coated and it just looks damn good looking underneath!
Old Jan 8, 2004 | 01:00 AM
Shue97_Z28's Avatar
thanks for all the input on the coatings guys i really appreciate it. im definately gettin coating on my LT's i just wasnt sure if there was a big advantage to one over the other. thanks again
carguy0119
Apr 11, 2016 11:11 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Scorch1
Jun 30, 2015 11:24 PM
LT14LIFE
Feb 9, 2015 09:35 PM
ferraricameron
Jul 29, 2002 07:46 PM
