CC306 ground wrong?
Old Jul 22, 2011 | 08:59 PM
formula-bird's Avatar
CC306 ground wrong?
The cam is a Comp Cams 290HR-12 (CC306). The camcard shows the cam to be a 108 C/L. Shows intake valve opening at 37 degrees BTDC. Degreed the cam several times with same results. The cam comes in at 107.5 C/L but the intake valve opens at 48 degrees BTDC, obviously 11 degrees early. Anyone else ever run into this situation?
Old Jul 23, 2011 | 05:24 AM
bw_hunter's Avatar
Re: CC306 ground wrong?
Check the cam card to see what they mean by open. It could mean a lift of .050"..
Old Jul 23, 2011 | 10:07 AM
Thanks for the info. Upon closer examination of the fine print, valve timing is at .006" lift. That corrected the problem.
Old Jul 23, 2011 | 11:31 AM
95zsean's Avatar
I've read ALOT of stuff on this site, but I've never read anything like this....
Good Info....
Old Jul 23, 2011 | 12:30 PM
http://www.compcams.com/Company/CC/c...csid=1103&sb=0
Valve timing is measured at 0.006 lift
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
92_RS_305
Sep 8, 2015 07:47 PM
