How much will it cost to rebuld my motor
Old Jul 15, 2011 | 01:20 AM
mgb1977's Avatar
I have a 1995 Camaro which spun a bearing. I just want I idea of cost to rebuild my motor. The top part of the motor is pretty good. Pls give me an approximate cost on rebuilding lower bottom of the motor and to rebuild the entire motor. Pls advise And pls let me know were I can get the parts at a good cost.
Old Jul 15, 2011 | 01:44 PM
JeeperSC's Avatar
Re: How much will it cost to rebuld my motor
Scoggin-dicky parts center
Old Jul 15, 2011 | 06:45 PM
dennis5374's Avatar
Depends on how cheap u wanna go
Old Jul 16, 2011 | 07:00 AM
rwb's Avatar
rwb
You might want to have this put in the LT1 section not the LS1 section.
Old Jul 23, 2011 | 06:42 AM
AL SS590 M6's Avatar
Moderator
I'll take care of that.
Old Jul 23, 2011 | 07:38 AM
Procharged94Lt1's Avatar
Anywhere from a couple hundred if all you need is bearings and a clean up if you do the work yourself all the way up to thousands of dollars..
Also- little harder to give advice without knowing what motor you have..
Old Jul 23, 2011 | 08:32 AM
RamAir95TA's Avatar
Expect at least $1500.
Your best bet might be finding a lower mileage short/longblock if you're hard up for $$$. I have one if you're interested.
Old Jul 23, 2011 | 12:33 PM
OP hasn't been back to this site since 7/18
Queens94z28
Mar 23, 2015 08:06 AM
indiana115
V6 Tech
Feb 10, 2015 06:25 PM
NewsBot
Dec 17, 2014 02:50 PM
MadMav
Dec 14, 2014 06:19 AM
