Catastrophic Oil Failure
Old Nov 7, 2004 | 11:41 PM
JOE96Z28SS's Avatar
Unhappy Catastrophic Oil Failure
I just dissasembled the rest of the Block and every bearing has been wiped out I think the Crank is FUBAR, everything else should be OK the cam bearings started to wear. I can't seem to figure out what the hell happened! The oil pump is fine the engine had oil. the pump was working, any Ideas? I completely dissasembled the oil galleys, removed everything and I can't find anything plugged. BTW this all happened on one drive.
Old Nov 8, 2004 | 12:21 AM
sleeperz28's Avatar
Re: Catastrophic Oil Failure
Did the oil get too hot and brake down? Does the car have the factory oil cooler? Mine got clogged a few years back and took out the cam and lifters
Old Nov 8, 2004 | 12:37 AM
1racerdude's Avatar
You spraying?
Old Nov 8, 2004 | 12:38 AM
Moving to "LT1 Engine Tech".....
Old Nov 8, 2004 | 01:11 PM
JOE96Z28SS's Avatar
No SPray and No Oil Cooler, EVERYTHING Looks Great, I can't figure it out
Old Nov 8, 2004 | 01:21 PM
Spinner's Avatar
You lose one, the rest are soon to follow. Debris in the oil will kill every bearing in a VERY short period of time.
94Form
Jul 17, 2015 10:56 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
