Cascading Failures LT1
Old Feb 28, 2022 | 09:14 AM
  #16
EMC Z28's Avatar
Re: Cascading Failures LT1
Originally Posted by Injuneer
Just curious….. you said you had four codes, related to the Opti and ICM. In response, in post #2 I gave you a link to Shoebox’s Opti diagnostic writeup, and suggested the diagnostic was required. Did you ever follow up on that? If so, what were the results. If not, why not?
I did do those tests and isolated it is not the PCM. I just didnt post it. The ICM seems to be testing properly too.
Old Feb 28, 2022 | 10:08 AM
  #17
So the Shoebox tests showed you that the Opti pulse signals were reaching the ICM???? Even though the Opti appears to be seriously damaged???
Did you check all the Opti harness connections, as I suggested in post #2? Surely that would have alerted you to the problem with the fire damage. Something just doesn't add up in this thread.
Old Feb 28, 2022 | 11:55 AM
  #18
EMC Z28's Avatar
The fact that I dont post absolutely every step might be why you are confused. I could not test the pulses because It would not start. I did the test below because its all I could do. ICM Harness
A = ~10vdc-12vdc (or your system voltage)
B = 1vac-4vac while cranking
C = ~ 0 ohms to ground with key OFF
D = ~10vdc-12vdc (or your system voltage-might be slightly less than reading at "A")
At the end of the optispark harness (disconnected from the opti) with the key ON, you should see:
Optispark Harness
A = ~5vdc
B = ~5vdc
C = ~12vdc (or your system voltage)
D = ~0 - 0.2 ohms ground with key OFF
I also tested the ICM in this method.
You don't need a whole lot of stuff, heck, you don't even need a scan tool (tho' a scan tool is important to have, but not for this article)! Here is what you're gonna' need to effectively use the information in this article:
  1. A multimeter (don't have a digital multimeter? Need to buy one? Click here to see my recommendations: Buying A Digital Multimeter For Automotive Diagnostic Testing).
  2. An LED light. To see a photo of this tool click here: Abe's LED Light.
  3. A 12 Volt test light.
  4. A helper to crank the engine.
It passed.
Long of short, The Opti IS bad and being replaced.
Old Feb 28, 2022 | 02:12 PM
  #19
Apparently you don’t understand the purpose of the first test. IT IS A TEST FOR THE PULSES REQUIRED FOR THE COIL TO PRODUCE A SPARK. If you measured the voltage on pin “B” and it was not in the range of “1vac-4vac while cranking”, you were not getting the pulse. That is a fairly significant result, and should have been communicated. But I guess that was too much to ask, and you went off on the fuel system.
Good luck.
Old Mar 1, 2022 | 04:12 AM
  #20
EMC Z28's Avatar
Maybe you didn’t understand. This car had multiple failures in a very short amount of time. Fuel pressure regulator was the start. I wasn’t just asking about the Opti. From the codes and testing I was damn sure it was intermittently failing to give signal. I was asking how a regulator could have caused cascading failure of multiple systems which didn’t compute in my little brain. Now that I have seen evidence of a fire, it explains why so many systems took a dump at the same time.
OrbitalChris
Oct 7, 2008 06:26 PM
CamaroCasanova
Apr 28, 2007 06:26 AM
whitemusclez28
Jan 31, 2006 10:30 PM
cozmo
Jul 24, 2004 04:17 PM
DanTheIROCMan
3rd Gen / L98 Engine Tech
20
Apr 16, 2004 03:54 PM
