Car is running bad once it warms up. Need Help!
Old Jul 31, 2006 | 07:38 AM
  #61
Sweetred95ta's Avatar
Re: Car is running bad once it warms up. Need Help!
Originally Posted by ShowStopper540
ICM!!!, i had a friend with a 1995 TA, and his would do this exact same thing, it would idle fine cold, warm up, sputter and die, sumtimes we couldnt start it without waiting as much as an hour! the ICM has built in resistors and whatnot (as with most electronic ignition components), when the motor heats up, and the heat dicipates to the ICM, it fouls up, and soon enough will stop firing properly or stop firing all together, sumtimes waiting 5 or 10 mins will do the trick, the TA finally quit doing it all together, it wouldnt start at all, we replaced the ICM, charged the battery. fired her up and shes been running good ever since! i would replace my ICM if i were you, and if that doesnt cure it, my coil would be next.
NOTE:: Neither of these failures will put out a code
Test the coil before you buy one. There also is an ICM cooling mod that can be done. Both of those things are located on shoebox's website.
Old Aug 1, 2006 | 09:44 PM
  #62
kainZ's Avatar
funny that i now have a similar problem.. but i think it is plugs and wires just showing itself a lot worse once closed loop engages and the computer tries to hypercompensate.. (in my case)
Old Aug 5, 2006 | 07:57 AM
  #63
97BBlackZ's Avatar
how can i check the coil??
Also what are some ways that i can check and see if the 02's are getting the right Volt.
Old Aug 7, 2006 | 07:19 AM
  #64
For the coil:
http://shbox.com/1/coil_testing.jpg
As for the O2's, I don't know if you mean checking what voltage they have in operation or what voltage the source has. The source has 5V. The O2 in operation will range from <.100V to <1V. They bounce around quite a bit trying to keep the car at an a/f of 14.7. If you put a scanner on them and they read .452V all of the time, then they are bad.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Injuneer
Dec 15, 2014 09:36 AM
cmdeshon
Dec 12, 2014 10:51 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
