car boggs out need help!!!
Old Aug 11, 2005 | 11:15 AM
1crazylt1's Avatar
Ok so this happen twice i was driving n then car starts to bog out then check engine light comes on then it just shuts off..does anyone no the problem
Old Aug 11, 2005 | 11:38 AM
Re: car boggs out need help!!!
If you pulled the code, its would probably make it easier to figure out
Old Aug 11, 2005 | 12:35 PM
1crazylt1's Avatar
i got that code puller that makes the check engine light blink but it didnt blink so in the book it say if it doesnt blink i have a problem that needs to get fixed any other ideas? i mean i would bring it to a shopbut it wont make it thier..
Old Aug 11, 2005 | 01:56 PM
white/blackss's Avatar
you cant blink the check engine light on a 94 car, it has to be scanned with a real scanner like a snap on or something.
you will probably have to take it to like a goodyear store or something, there cheap enough and should still have the right scanner to tell you the codes.
Old Aug 11, 2005 | 02:33 PM
1crazylt1's Avatar
got my codes ran at the automovtive shop down the street the code came up temp sensor..it ran -40 degrees..soit would dump more fuel into the motor cuz i thought it was cold..n yes u can make the check engine lite blink..the guy said it mite be the sensor or wire..
Old Aug 11, 2005 | 02:39 PM
1993 is the only 4th gen that you can blink the light on, i had that scanner that blinks the light too and i learned on here that you cant use it, it could possibly cause pcm problems, anyways, i got mine scanned and it worked fine.
if the guy down the street was able to get a code from it then there is no broken wires, on a obd1 car there is only four wires that the scanner uses and they are
1. battery power
2. ground
3. pcm trigger
4. data serial wire
if any of those were bad it would not give anything.
Old Aug 11, 2005 | 04:37 PM
1crazylt1's Avatar
thanks fo the info just came bak formt he chevy dealership n ordered the sensor
Old Aug 11, 2005 | 05:37 PM
A reading of -40degF = infinite resistance = an open circuit. As he said, could be a bad wire (or harness connector off the sensor) or faulty sensor.
At least he got that part right. You can NOT flash the codes on a 94, as at least two people here have told you .
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
