Canton oil pan and dip stick tube???
Old May 27, 2007 | 07:53 PM
95Z28ConvtM6's Avatar
What's the trick to getting the dip stick tube to go in all the with a Canton oil pan? Anybody else have any issues? Thanks in advance!
Old May 27, 2007 | 08:25 PM
CANTONRACER's Avatar
Years ago I ran into this problem.
I cut my dipstick tube shorter to fit in.
Then I put my dipstick in and the next time I checked my oil a chunk of my disptick was gone.
So I have one broken dipstick in place all the time and a good dipstick I put in when I need to see the level.
Old May 27, 2007 | 11:38 PM
chrp3rd's Avatar
canton
me and my friend just had this same problem last weekend and the only thing we could do was cut it
Old May 27, 2007 | 11:58 PM
JP95ZM6's Avatar
I just fixed this issue today, with a Canton 242-t. When I test fit the pan, I could see that the crank scraper welded in the pan blocks part of the dipstick passage. I just ground that part of the scraper out, about 3/8 inch wide. Then disassembled pan and cleaned it real well to get all the metal dust out.
If you have the Canton bolt-on pickup you should check the clearance to the pan, too. Mine was touching with no gasket. Couple taps put it a 1/8 inch.
Old May 28, 2007 | 06:23 AM
cehan's Avatar
That's exactly what I had to do with mine, plus grind out the scraper to clear the rods on the stoker crank. The tube was still hitting on the 4 bolt main bearing cap, but a slight bend on the tube took care of that.
Old May 28, 2007 | 07:08 AM
FASTFATBOY's Avatar
I wouldn't grind on the pan, all ya gotta do is where it is touching is tap it with the round end of a small ball peen hammer until it clears. But to each his own.
I was gonna clearance mine up near the block where the little "V" is made in the pan for the dipstick, that is where mine hit going in, but I was afraid of it cracking there later..I just cut the tube off, put some sillycone on it and put er in.
David
Old May 28, 2007 | 08:16 AM
David
Thanks for all of the replys! Unfortunately, I bought a project car and the engine is already in the car and running (or was running - I'm getting ready for the turbo kit.). The engine also has splayed 4-bolt main caps which I understand adds to the problem.
It looks like the tube is hitting the "V" of the pan, but the dip stick itself appears not to go beyond this point either. I Don't have a problem with cutting the tube, but what dipstick works? I really don't want to pull the pan at this point, but...
Old May 28, 2007 | 08:31 AM
FASTFATBOY's Avatar
Stock dipstick and tube works, 6 quarts in the pan, one in the filter.
I use the "add" mark as my full mark
David
Old May 28, 2007 | 09:36 AM
David
So you cut the tube, but not the dipstick?
Old May 28, 2007 | 09:50 AM
FASTFATBOY's Avatar
Yes, tube only. Why would you cut the dipstick itself?
David
Old May 28, 2007 | 10:04 AM
Becareful because the disptick can get pulled into the rotating assembly and chewed up.
Old May 28, 2007 | 10:06 AM
David
Just confirming - the dipstick wouldn't provide any benefit if it was cut.
However, it seems like the dipstick is stopping at about the same place without the tube in the picture, but I was just eyeballing it. I'll take some measurements today. Thanks!
Old May 28, 2007 | 10:11 AM
It has the stock stroke, so hopefully there won't be any issues using the stock dipstick and tube. The tube has a stop on it where it contacts the block regardless of how much I cut off below the stop, so it should provide the same length in the engine as the original set-up. Well, it makes sense to me anyway
Old May 28, 2007 | 10:16 AM
cehan's Avatar
David
After grinding the notches in the scraper for the rods to clear, one more notch for the dip stick tube was no big deal.
David
I was confused about how much oil to put in the pan so I called the Tech Line at Canton; they told me the pan makes it a 6 qt. system. Fill the filter then put the rest of the 6 qts. in the pan
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Cam's maro
Dec 29, 2014 08:44 AM
