can't get my SuperDamper off!!!!
Re: can't get my SuperDamper off!!!!
If you mean the engine is rotating then I recommend a Crane brass piston stop. Turn the engine by hand until the piston contacts the stop and then use the puller. If it happens to be a stick then put it in the highest gear and you might try the parking brake. You would probably have thought of that if it was a stick though.
Originally Posted by blackztpi
i've tried a puller several times. i can't get that damn thing off...yes, i am pullin on the damper and pushing on the bolt in the crank. help
Personally I have never had a damper that would not come off with a puller...take a good look and make sure you are pushing on something that isnt supposed to come off with the damper.
i don't want to weaken anything with heating. the ati superdamper is actually much easier in looks than the stock setup. i have a bolt in the end of the crank, which i am using to push off of on the puller which is connected to the balancer
Originally Posted by slopokrodrigez
Are you sure there is no washer on the bolt and the bolt is backed out far enough so the head is not on the flange of the damper?
