Superdamper install
Old Mar 18, 2010 | 01:29 PM
leftoverz28's Avatar
Superdamper install
Im trying to install a new ATI superdamper on my lt1, but im not sure how far to press it on, and dont want to start stripping threads. Anyone have any info on this? a measurement from the opti to the back of the dampener would be awesome.
thanks for any info.
Old Mar 18, 2010 | 02:29 PM
What year is the engine? Does it have a CKP sensor? Are you using the spacer that comes with the ATI?
You need to add a "signature" with basic info about your car - year, model, engine, tranny and any major mods. That way the required info is always attached to your posts, so peole can help without asking a lot of questions.
Old Mar 18, 2010 | 02:43 PM
MikeGyver's Avatar
I imagine you bolt it on tight till it stops (hits the crank timing gear).
Old Mar 19, 2010 | 05:07 PM
im pretty sure the engines a 94 and i dont think theres a crank sensor. i put the spacer on the crank before the hub.
Old Mar 19, 2010 | 06:01 PM
You would know if there is a crank sensor from the timing cover:
http://www.enginebuildermag.com/Cont...0000003989.gif
If you put the spacer on, and it seated so the pulley is in line with the accessory drives, you don't have a CKP. Put a straight edge across the various pulleys to make sure the damper pulley is aligned properly. In the end, that's what matters.
Old Mar 27, 2010 | 05:39 PM
ive tightened it to the point where im pretty sure it wont go on any more, and measuring from theback of the pulley to the opti there is about 1/8 inch more than on a stock 93 motor. unfortunately i still have to build the accessory setup so i cant line them up.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
