Can the Street Twin be rebuilt?
Old May 2, 2003 | 03:01 PM
SloCal94's Avatar
I am getting ready to install my new 15psi 355 and was wondering if the Street Twin is rebuildable or what do I have to buy to make it like new again. The clutch has about 60,000 miles on it and showing no signs of slipping, but since I will have the car apart I would feel better with a new or rebuilt clutch in it. The clutch has worked perfectly since new except for a leaking slave cylinder POS. I switched back to the stock sleave and it has worked fine ever since. Does the new kits come with the sleave for the slave cylinder or do they automaticly come with mcleud's adjustable master cylinder?
Old May 2, 2003 | 04:41 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
Thumbs up
yes call les at mcleod, and send it to him, they will resurface both flywheels and put new stuff onto your clutch plates
their customer service is great!
Old May 2, 2003 | 06:05 PM
IllusionalTA's Avatar
325.00 same day in and out usually depending how swamped they are.. Great Service...
Old May 2, 2003 | 09:08 PM
SABLT194's Avatar
Les at Mcleod is a good guy to work with. They redid mine after a full season of bracket racing (10 passes per week) . I did have to shave some off of my throw out arm pivot point after the rebuild to eliminate some interferrence problems however.
Old May 3, 2003 | 11:30 AM
ZBLKHELLRZR's Avatar
Did I read that correctly? 60K on a ST? You do a lot of track time or just day to day driving on that? Most guys it seems get only 3 yrs or so before time for another rebuild but they of course beat the snot out of it.
Old May 4, 2003 | 03:25 AM
SloCal94's Avatar
yes 60000 miles. That includes about two dozen eighth mile runs and the rest are street miles. It was more then I needed at the time when i got it but now it is just perfect. I would recomend it to anyone.
Old May 4, 2003 | 07:58 AM
taner's Avatar
200.00 for the mcleod slave i believe. funny thing i had to clearance my fork pivot arm as well. would've been nice to know ahead of time!
Old May 4, 2003 | 05:34 PM
Any pics of this? i just put my rebuilt one back in and luckily have no issues.. but if i do take it out again be nice to get that outta the way,..
Old May 4, 2003 | 06:07 PM
taner's Avatar
hmmm no pics but the idea of it is on the fore/ front side of the pivot fork it was contacting the studs on the pressure plate. that is why grinding was required. as soon as i turned the key you could hear the fork hitting something, the something turned out to be the studs coming thru on the pressure plate
Old May 5, 2003 | 03:52 PM
SABLT194's Avatar
I had exactly the same problem as Tanner. The fork hit the PP studs at full travel. I took about .09" off of my pivot point and every thing was hunky dory. I figure I'll just make up a .09" spacer when I need to get a new clutch (probably next year). Although, Mcleod is still working on the Blowproof Bellhousing for the LT1. Their arrangement should set us LT1 guys up for an Iron disk 3 finger slipper arrangement in the future. That should save us some $$$ in drive train components from the trans on back.
Wishing I had that stuff right now!
Steve
Fastbird93
Jul 11, 2015 04:37 PM
mrwz28
Jul 8, 2015 09:11 PM
Ringmaster72
Mar 19, 2015 03:32 PM
Ringmaster72
Feb 25, 2015 03:15 PM
RichJ
Aug 11, 2002 10:14 PM
